A 1200A frame breaker with 600A trip unit is installed on a 480 VAC 3 phase standby generator that feeds plant distribution through a 3 pole / solid neutral ATS.
My understanding is with the 600A trip unit, no GFP on the breaker is required (actual overcurrent device installed). If they need the GFP enabled then the 3 pole ATS could present a problem.
Am I correct that no GFP required in this case?
