Good morning,
I come from the IEC world but usually do grounding grid calculations following IEEE 80-2000.
I have been reading through IEEE standards for some information about how to procceed when you have a distribution transformer substation. I mean:
for the transformer primary voltage, you design a ground grid for safe touch and step voltages as of IEEE 80-2000.
But then, you have the grounding of the neutral of the transformer secondary:
-What to do with it?
-Connect to the same ground as the HV grounding grid?
-Connect to a different ground?
In IEC world, both options are possible. I have a CENELEC document which addresses it, but I have not found anything about it in IEEE.
Any reference about it?
Thanks.
Thanks.
