SILVERFOX907
- ALASKA
Hello everyone, and im hopping to received help.
I started working at a gold mine, because of the recession. Its been a month now, but I noticed a lot of dirty power. Its a large open pit mine, with 13.8v feeding it. It takes about 40 minutes to drive around, with step down transformers along the way. 13.8v to 4160v or 480v.
Some things I’ve noticed is grounding, and bonding problems. Or lack of. Most of the structures don’t even have a main bonding jumper, or a GEC. It just Armored cable running everywhere, with out ground bushings entering an enclosure. They have had problems with well pump failures for awhile now, and replacing them.
480v some of them are 2,000’ + down a 6” or 8” hole.
One well had isn’t pump motor replaced 4 times this year. All the motors are 480v with different hp.
My question is can the grounding and bonding issues create harmonic issues, stressing out the motor. Creating a negative, or positive additional harmonic frequence, causing more torque on the rotor?
Some of the lift stations I can hear the a sound that i can’t explain, I want to say it’s dirty power, and the harmonics of it. Electricity doesn’t make noise, but you can hear a motor cooling fan.
