breevo
- Houston, TX, USA
I recently ran across Mike Holt's YouTube video, "Grounding - Safety Fundamentals (1hr:12min:19sec)" and have learned a lot from this video. I learned the importance of the equipment grounding conductor. I understand that it takes a high current to trip the breaker. But I also learned it doesn't take much current to kill someone. I had a thought though that came to mind recently and would like to know why it is not done this way. Presently, when a fault occurs, the path the electricity should take is the bonded equipment grounding conductor back to the source and with such low impedance, the high current trips the breaker. But you still are relying on a high current. So why don't they have a device right before the equipment grounding conductor is terminated at the source that will trip the breaker if it detects any current (or if you want to be technical, "a current >1 mA")? I would think this would be safer, unless there is a guarantee that all faults will result in a high current at the source. I'm sure there is a reason this is not done, so I'm hoping to learn from your responses. Thanks.
