360Youth
- Newport, NC
Had the craziest thing in some time happen today. We had added a couple of circuits to a small remodel job. One is for a small wall heater in a bathroom. It is one a timer switch in the same box as switches for a fan/light combo. The fan/light is hooked up to the breaker and I am stripping out the new new circuit for the heater at the panel and when I pull the sheathing off the wire I got lit. Quick scan for nicks or something else I touched and I see nothing. Put my touch tester up against the bare ground and it lights. When I turned off the lighting circuit the touch tester goes off. I thought maybe I did not tuck the ground away good in the switch box and it is hitting a screw for the fan/light. Checked the box and it was good. At one point I had 25 volts from ground (of the heater circuit) to neutral at the panel. I check again and get no readings. I hook everything up just to see what it does when I turn the lighting circuit back on. All mysterious voltages go away. I never did find any nicked or stray wires touching anything they should not.
