A ground fault occurred in my plant and the ground fault indicator on the main switchboard popped out causing the main to trip> It worked as it should have but the question I have is it went through 3 breakers to get to that fault indicator so it shut down the whole plant. The problem was a compressor in a roof top unit went bad. How come the breaker in the unit or the 3 pole 60A in the panel or the main breaker for the panel located on the switchboard did not trip? Any ideas would be helpful. Thanks
