I have been having a debate with my colleague at work related to using the "grandfather clause" for the following application:
My thinking is: if a panelboard is not being replaced, but only the source and load side wiring is being changed, the NEC code regarding safe working clearance does not have to be applied and the equipment can be grandfathered in.
What would be the forum's thoughts?
Thank You,
Thank You,
