Gray devices
I'm going to be trimming out a basement finish shortly and the home owner wants to use gray devices. I was planning on using Diva dimmers but the problem is the that gray Lutron uses is different than the gray Pass and Seymour use (P&S being what my primary supplier carries). I'm going to have a few boxes where there will be both dimmers and decora switches and I think that mixing the two is going to look odd. I called Lutron and they could not give me any info on what other manufacturers may be compatible. So I'm wondering if anyone here might have any ideas as to who might match the color that Lutron uses. And as an aside they want to go with the screwless plates so I need to make sure that they are available from the device manufacturer also.
Thanks
I just finished a rez job using gray trim. The dimmers were those Divas and the plates and other devices were Leviton. I didn't notice a difference, though it wasn't me who installed them but one of my guys. He's pretty conscientious and likely would have mentioned if they were different.
I'll talk to him tomorrow and post back. We didn't use those screwless plates though, don't know much about them.
Well aren't Leviton and Lutron the same company?
I would change the dimmers to something that matches the other devices OP is using.
