george t. everett
- New York
Is it permissible to ground a metal switch box by useing the clamp screw, without the clamp, or do I have to use a green grounding screw ?
I agree, thats what I have been trying to say all along, and wouldn't it be much better to use a green ground screw w/pigtail, g-clip, or green ground screw, it may keep you from getting a red tag, taking a chance on somthing as simple as that is IMO not worth the trouble. Most inspectors I deal with need to see a green ground screw or they will give a red tag. But then everybody on this forum says any screw, with the exception of a sheetmetal screw, will do as a ground screw.electricman2
Not according to 250.148(A). Most clamp screws I've seen do not have large enough heads to properly secure a conductor anyway.
That is a big 10/4Pierre
The stranded pigtail with the stakeon fitting is a nice way to go, easy and fast.
Not familiar with this, do you have a manufacturer and/or cat. no?The stranded pigtail with the stakeon fitting is a nice way to go, easy and fast.
I've seen this hack lots of times in older places...Originally posted by hs545:
gound wire is wrapped around the insulated portion of the wire and is under the wire clamp of the box
I agree with you that is hack now but that was how trade schools where teaching how to do it.Originally posted by tonyi:
