green exits
Leff, welcome to the forum. There are many Ohio members here and I'm sure one will come foward to answer your question.
Roger
Well it could be that mind set of Green - Go !
I read an article and someone mentioned traveling alot and paying attention to your exit routes.
I beleive it's be more of a building code issue, or even an Engineers preference... Frankly I think its the diode designers thinking there seeing red and will have none of it!:rolleyes:
In researching for this post, I haven't been able to find in the Ohio Administrative Codes any information regarding the use and/or requirements regarding green exit lights. Most of the requirements are in reference to energy codes. I believe THIS would have the authority to do so.
Not sure what part of Ohio you are from. Your local building department may have the answer.
check out OSHA 1910.145
Specifications for accident prevention signs and tags. Also covers what colros and lettering must be for other types of signage or instructions. This may help
