georgestolz said:250.119 requires insulated equipment grounding conductors (EGCs) to be #6 or larger in order to pull black and re-identify it green.
However, the question becomes: Is the conductor required by 680.26 an EGC? I don't believe it is, and therefore, I believe your installation should have passed.
Anybody else smell crow cooking?
Edit: Are you talking about the EGC of the feeder to the pool panel, or are you referring to the equipotential bonding conductor in 680.26?
It wasn't a typo, I misread the section and wrote what I thought it said.chris kennedy said:George I know it just a typo but 250.119 says
"larger than 6 AWG"
I agree - the reason I didn't know for sure is because I haven't installed anything larger than #10 with green insulation.A #8 with green tape is not going to burst into flames.(IMO)
Dmagelec said:I thought a licence electrical contractor can re identify wire
celtic said:License or not...code is code (whether your installation is a violation/not a violation is another story).
brian john said:What's this the G-NEC, oh if we could just do as we thought it said.
don_resqcapt19 said:But Tom, you have to admit this is a stupid rule....there should be no need to identify the EGC by color....if you can't tell what it is by looking at the terminations, you should not have the cover off the panel.
Don
