aftershock
- Memphis, TN
My boss had me go move a panel that was obstructed by a new greenhouse that has been built.
While I am to be there doing this, my boss wants a material list on what we will need to wire the electrical in this greenhouse.
It has:
1 htr unit @220/v 54 amps
2 ac units? @110/v 7.3 amps each
2 actuators<sp> @110/v .25 amps each
1 fan, I guess to just keep air circulating and since I did not check the amps, I can only guess about 3 amps.
Customer will want about 3 quad receps and one other switched recep for rope lighting.
Customer wants me to use pvc for my conduit.
Customer has all the equipment on site except the rope lighting which I guess he will just plug in and run it how he wants.
There will be 5 high voltage thermostats to control the htr, ac, ac, actuator, actuator.
I have never wired a greenhouse, I have only done service calls on one and replaced things. I pretty much know how everything is going to work, I just have a hard time coming up with a material list because this seems to be one of those "make it up as you go along" because I dont know what I am going to run into trying to feed all 5 pieces of equipment from 5 different thermostats until I start working with it.
First problem I see is: All the thermostats break only 1 leg. This is fine for anything running at 110/v but I have a feeling I will need the thermostat for the 220/v heater to control a 2 pole contactor instaed of going straight to the heater. I will also need a means of diconnect within sight unless I can use something to lock the breaker in the open position.
2nd problem. Customer wants me to cut the cord caps off of the ac units. I dont think I should do this. I know he wants to save money by not having another opening charged to the job, but even if I could get away with hardwiring these 2 units in,, I would have to have a 20 amp switch as a means of diconnect.
3rd problem. Customer wants pvc to reduce the cost of materials. I remember reading another thread (cant find it now) where someone posted that pvc is not good in a greenhouse environment due to chemicals?
Plus , unlike using emt, I will have to have prefab 90's and 45's and knowing how many I could possibly need is hard to determine.
4th problem being my boss. He wants to get this material list in so he can give a price and thus get us some work because we are at a dead stop. Other than the knowns, all I can write up is like, a box of this fitting, that fitting, 100' of this pipe and a spool each of hot, neutal and ground #12 thhn.
Im an installer Jim, not an estimator.
Any do's dont's and suggestions as far as type of material to use would be helpful in figuring out what to list and what to explain to the customer as to why we need to do it this, or that way.
Pictures attached
It has:
Pictures attached
