I have run across a rather grey area in the NEC that I would like to get some clarification on. I have a MCC unit with starters that control the roof top fan systems and other motors around the plant. Under the new 2008 NEC 430.102(A) it requires disconnects within site of the motor being controlled and the controller. The exception reads that you do not need a separate disconnect for the controller if the controller is lockable.
So my question:
Am I required to provide a separate means to disconnect power to the
motor within line of sight of the motor if my starter or disconnect in the main gear that supplies the branch power to that motor is lockable and the facility has a written lock out tag out procedure?
Example: 480V 3 Phase Rooftop fan does not have a disconnect or controller on the roof or within sight of the roof top fan motor, but it is supplied with a Starter Bucket in the MCC that can be locked in the open position and the facility has a written lock out tag out procedure.
I have always thought I was required to provide some means for disconnecting power to the fan unit within line of sight of the motor whether it was a lockable controller or lockable disconnect.
Thanks
So my question:
Thanks
