I am working on a rooftop grid connected system of 3 inverters of 2 X 100kVA and 1 X 60kVA and the wiring configuration for 400V is 3 phase, 3 wire system, and for the utility side its 240V 3 phase, 3 Wire system. in this case can I use a delta-delta winding transformer or will I still need a wye with neutral point grounded on the 400V side (PV inverter side)?
appreciate a quick answer in this regard
