As a DIY guy I need some electrical code advice.
I am installing a grid-tie PV array for my house. I got everything installed and flunked my final electrical inspection due to an issue with my tie-in to the main breaker panel.
I have a 150 amp main panel, but if you add up all the breaker values in the box the total is about 680. This was pretty much the original configuration as I haven't really added any breakers since I bought the house many years ago. The inspector said that probably would be OK if you can show that not all the loads are being used simultaneously, but when you add a circuit for PV then this no longer applies. He?s saying that with the PV I now need a service panel rated so that my total breakers don?t add up to more than 120% which in this case would be a 560 amp panel. He?s saying there?s no other way around it. This doesn?t sound right to me.
I don?t think you can even get a residential panel for that much current can you? The most I?ve seen is usually about 250, so I?m thinking this guy must be wrong or else nobody would be able to get PV installed.
Can anyone clarify this for me. Thanks
