What do you do when inverter keeps shutting down due to high AC V?
3 @ 30 kW commercial ABB inverters.
They keep shutting off due to high grid voltage. Not sure how to deal with that outside of catching it when it happens or putting some kind of remote monitoring on it. I find it hard to believe grid would be at 15% over spec V.
But all 3 inverters show some degree of overvoltage.
Minor add'l Q's:
-is it malfunction or genuine high V?
-can V window be set/widened? What are implications of doing so?
-why are there high V events in the first place? I was told that due to hot weather and the heavy A/C loads that result, a utility often bumps up V to add more power to grid, w/o exceeding Ampacity limits.
Minor add'l Q's:
