Good evening everyone,
I am working on a small project. I must to provide power for a new grinder pump, 1ph, 230V, +/- 5% Voltage tolerance, FLA=11.3 Amps.
There is an existing 3ph, 120/208 Y panel with capacity to handle the new grinder pump.
I am going to provide new buck-booster transformer to boost the voltage from primary 208V 1ph to secondary 230V 1ph.
I have done some research in the forum and Internet regarding the buck-booster transformer and I am not still clear for boosted line voltage and voltage to neutral.
My questions are below:
1. Can I use one of the secondary voltage and N to have 120V (for grinder pump control) or I must extend a separate 120V circuit from existing 120/208, 3ph panel?
2. What are grounding requirement for a buck booster transformer?
Thank you in advance.
