jjhoward
- Northern NJ
- Owner TJ Electric
Hello all;
I will be re-wiring this grinder pump. The original UF cables have been cut and spliced together with the yellow twist lock weather proof connectors you see in the photos.
The black connector accommodates both cables for the pump (a 240V 15 amp line and a 120V 15 amp line). I am not sure if I need to replace that black connector or are the wires under lugs that have set screws so I can just bring in my new cables?.
Is this connector familiar to anyone?
A part number or a hint where I might find some info about that connector would be great.
Thank you all.
Thank you all.
