F fifty five Member Apr 29, 2009 #1 is plastic bushings okay to use or should you use grnd bushings inside hoffman metal enclosure all conduit emt.
Rockyd Senior Member Location Nevada Occupation Retired after 40 years as an electrician. Apr 29, 2009 #2 All depends on what the Hoffman box is going to be doing. Take a look at 250.96, 250.97, 250.98, should be proper consideration for whatever application you have in mind. Answer based on a 2005 NEC...
