Leigh Simpson
On YouTube someone mentioned in the 2020 NEC there will be a need for a grommet or bushing in the hole of the cabinet where the dishwasher cord passes through. I haven't found the code section. Has anyone? Thanks
Thank you. I wonder who will do this protection since the cabinets are installed by the GC or the cabinet maker? And then the plumber installs the dishwasher with the cord and water line, often times before the electrician returns for final trim out. Anyway that will need to be figured out. "Other approved means" leaves it open for a wide interpretation. Thanks again for doing my homework for me haha.422.16- B ,2- 5
I hear what you are saying, and we definitely will have to coordinate on the size of the hole with the installer. Thanks again, for the quick code section . . .It's crazy for wood. They make a two piece grommet that we use when installing Romex through metal studs. I suppose that might work.
I'm guessing that a specific product doesn't exist. I think that a furniture grommet might be good enough.Is this just the 2020? And what device out there to accommodate the requirement? Tried to find something but found nothing that would allow the plug head in. Most everything I've found where related to desks for Cat, phone, and computer hdmi to come thru but nothing larger.
Its a 2020 change. T&B makes a 2" plastic KO bushing, might work on thicker wood instead of metal box.Is this just the 2020? And what device out there to accommodate the requirement? Tried to find something but found nothing that would allow the plug head in. Most everything I've found where related to desks for Cat, phone, and computer hdmi to come thru but nothing larger.
Wouldn't surprise me if it did.Wonder if it needs to be listed.
I'm thinking sump pump hose. That's 1-1/4"I wonder if you could take split loom and ring it around the inside of the hole. That would make a fast grommet to fit any size hole. And heck, its even made for electrical usage.
