gronded conductor
domnic
Electrical Contractor
On a corner grounded three phase delta service the grounded conductor is marked white at the meter base and in the panel. once a three phase branch circuit leaves the panel must you mark the grounded conductor in the branch circuit white ?
ggunn
Austin, TX, USA
Of course. Why wouldn't you?
petersonra
Northern illinois
engineer
it is still the grounded conductor.
don_resqcapt19
Illinois
retired electrician
While the code requires that grounded conductor to be identified just like any other grounded conductor, in the 20-30 grounded phase systems that I have seen, I have never seen the grounded conductor so identified.
