emiller233
- pittsburgh, pa
there's a debate going on here...
whether it is mandatory or not to ground a limit switch (metal body with 1NO-1NC and a ground screw).
this is being used as a door switch for entering an area. Its a big industrial hydraulic unit with metal enclosure around it to keep the weather off of it.
The switch will turn on/off a 24vdc LED light fixture when the door is open, lighting up the area inside the enclosure. the LED light does not have a ground (2-wire).
crude sketch attached to show the wiring
Lights
PATLITE CLA12S-24-CD-30
https://www.patlite.com/product/index.php?Command=Index&method=Download&id=191&idx=4
https://www.patlite.com/product/detail0000000191.html#related
Limit switch
Omron D4B-2171N
http://download.ia.omron.com/download/page/D4B_2171N/OEI/D4B_2171N
https://www.ia.omron.com/product/item/9919/
Lights
Limit switch
Omron D4B-2171N
