Re: ground and bond testing
Hello-
Like the others, I'm curious as to who is asking you to start this program.
I suspect that you are looking for something that OSHA calls the "Assured Equipment Grounding Conductor Program", where the construction industry performs routine electrical testing on equipment, hand tools, and grounding systems at the job site. You can find out more information at
www.osha.gov under their electrical section or just do a google search.
If this is not what you are looking for, you might try talking your boss out of having to start such a program- unless he or she is willing to invest in the correct equipment and do the job right.
I've seen too many electrical contractors try to get involved in the electrical testing business, but they try to do it on the cheap.
A quality 3-point fall of potential tester, used to measure the earthing portion of a buildings grounding system, runs about $3,000. A ground impedance tester, used to check the equipment grounding conductor and bonding side of a buildings grounding system, can cost up to $6,000.
These instruments also require routine calibration, which is about $500 annually for the pair.
What I typically see are companies using a $300 dollar "Sure-Test" wiring analyzer and a $1200 AMEC clamp-on resistance tester to do this job. These are fine tools when used properly and according to manufacturers instructions, but I wouldn't stake my companies reputation on them as it is too easy to get an incorrect reading.
Good luck,
Mark
