Hello,
I have a hum problem in a home theater installation when I connect two pieces of equipment on separate circuits.
In the sub-panel, the electrician added an additional ground bus. The original bus appears to have a separate non-insulated cable which presumably connects to the main service panel.
The second ground bus does not appear to have either a connection to the grounding point in the main panel, nor a connection to the original bus bar. It is bolted to the sub panel enclosure. Only 240v circuits appear to be connected to the secondary ground bus.
Is this a problem?
Thanks,
Rob
Is this a problem?
Thanks,
Rob
