scotteng
- Apollo Beach, FL
- Professional Engineer
Does anyone make a bushing for a 750 Kcmil ground riser? Have a project in CA where a bare ground needs to be routed via a seismic joint and the current thought is to route via metallic sleeve, but can't find any way to bond both ends. FYI - can't use PVC due to above ceiling being uses as a return air plenum.
