Alwayslearningelec
- NJ
- Estimator
Would you using a MIGB on the end of PVC conduit entering a manhole? I'd think not because of it being PVC. THanks
No.Would you using a MIGB on the end of PVC conduit entering a manhole? I'd think not because of it being PVC. THanks
Malleable or die cast. I prefer die cast.I know spec determines but if you have RGS elbows/conduit stubbing up from underground into bottom of gear would you use a MALLEABLE bushing or other material?
Malleable Insulated Grounding Bushing or sometimes called Metal Insulated Grounding Bushing.OK, MIGB?
