If all the concentrics have been removed and if you clean any paint off as required by 250.12 you are not NEC required to use a bonding bushing.
UL lists reducing washers as suitable for grounding.
That said, I would at least pull a green in with the circuit and if that could not happen I would install a bonding bushing ........ but that is just a personal choice.
