Ground Clips?
The Iceman
Florida
I have seen these Green Ground Clips for years but have never used them. I don't see any UL listing on them. The ones I am referring to come from NSi, cataloge #GGC-1000. They are for #10-14 copper. Are they listed to use for bonding equipment grounding conductors to metal enclosures? I would say no, 2008, 250.70, 250.8 A.
Why would they not comply with 250.8(A), just because they are crap? The last resort?
Exibit 250.3 from the 08 NECHB.
Every once in a while the grounding clips come in handy, say for grounding an old box without a tapped hole for the ground screw.
Agree, I always have them on me just for this reason. Unless of course the customer wants to add changing a box as an extra.
If the back of box is tight to a brick wall/steel beam or some other item you would rather not deal with:
...and it's not even broken.....yet :D
these from greenlee are great
showImage.ex
Yes they are, and by some sheer coincidence, the 10-32 is the one I've used the most by far. One thing you should be sure of is that the drill tip punches through what you're drilling before the threading teeth start grabbing.
That matters because, when I get a box without a dimple for the green screw, and I'm molunting it to sheet metal, I mount the box, then drill and tap the hole, so the threads match.
That's what's known as a bottoming tap. I've recommended them here, too. Their main use is for threading closer to the bottom of a blind hole.
