I am looking for some input on a job we are doing. The existing conditions
private service transformer secondary 120/208 3 ph. feed under private road to a 1200 amp 120/208 3 ph service. We are planning on intercepting 3-4" pvc conduit running from transformer to service across street. Installing a spiceing hang hole, where we will run feeders from transformer to new 3R service rated transfer switch. which will be feed from new generator and existing service. My question is this:
The exiting transformer has a bond grid in place with ground rod driven. The exisitng service across the street has a ground grid with ground rods/building steel. I am planning on installing ground grid 2- ground rods at new generator. The exisitng triple 600 mcm in 3 -4" pvc conduits running across street do not have a ground conductor in conduit. Will I need to install one once I intercept at new hand hole? I looked at 250-32 and I am looking at this as a seprate building and I am under the impresion that I will not need them. Any imput will be appreciated.
