hardworkingstiff
- Wilmington, NC
Here is the scenario:
Meterbase will be installed a couple of hundred feet from the begining of the fixed pier. An enclosed circuit breaker will be installed adjacent to the meterbase (disconnect 1). Another enclosed circuit breaker will be installed at the beginning of the fixed pier (disconnect 2). A 400-amp MLO panel will be installed out on the fixed pier and fed from disconnect 2. Parrallel 4/0 conductors will be pulled from the meterbase to disconnect 1 then to disconnect 2 then to the MLO panel.
Here's the questions:
Do you need to pull a ground conductor between disconnect 1 and 2, or can you ground the neutral at disconnect 2 and call it the service disconnect?
