gserve
- New Hampshire
I have a 100A disconnect on a pole that is going to feed a mobile home.The problem is that the neutral bar doesn
't have room to accommodate both the neutral and the ground connection. Question; Can I attach a bolt-on lug by machine screw to the enclosure to pick up the ground wire. This is the main service and the enclosure is bonded to the neutral bar.
