We are installing a 12K # mobile column lift. This unit features a main panel with all integral protection for the motors, control, etc. This main panel is fed via a 20 foot cord (30A, 480VAC 3 phase + ground). Our plant features an ungrounded ("floating") 480VAC service.
I would like some type of detection ensuring the main panel (attached to the mobile lift) still has a good frame ground connection, thus ensuring a phase to ground fault with the equipment will not result in the equipment frame being energized but instead will open the circuit.
Any ideas? I few of the items I looked at for ground fault detection require a 3 pole grounded whye source.
Thanks
Thanks
