BMacky
 - Foster City, CA
I have two panels in a system; one is the main, at a separate structure (pool pump and filter shed) that has a set of pass thru lugs that feed, via PVC conduit, another structure's (pool house) sub-panel. The main is grounded via GEC and rod; the sub-panel is connected to a U-fer. Do I need to run an additional ground between the two structures in the PVC? It is a 200 -amp service so I know a #4 gnd cond. would be appropriate if the answer is yes. What article clarifies this best?
Thanks!
			Thanks!
