Does anyone have any guidance on how to monitor a ground fault on a 2400 three phase system fed from an ungrounded delta-delta transformer?
Our facility previously installed a 2400V medium voltage motor control center. When the motor control center was installed, it was electrically fed from an existing three-phase three-wire ungrounded delta-delta transformer. The feeder to the 2400V MCC is approximately 200ft from the existing ungrounded delta-delta transformer. Do ask me why this was done this way. The switchgear drawings do not provide any details on ground fault indication.
NEC 250.21 covers systems 50 volts to 1000 volts not required to be grounded, but what about systems greater than 1000V?
