What is the current path if the negative wire in a DC PV system is grounded. I know that if the positive wire is grounded the ground current travels along the equipment ground conductor through the bonding jumper (ususally in inverter with GFD device) and then returns to the PV module
What happens if the negative wire comes in accident contact with the ground? Is there any current flow? What path would the current take?
I would not think there is any current flow since the negative and ground are at the same potential?
