dbrooks1027
- Northern VA
If an ungrounded conductor makes contact with the metal case of an enclosure, lets say a 120 volt circuit and the equipment grounding conductor is .5 ohm that would make it a 240 amp ground fault back to the source. My question is, isn't it dangerous for 240 amps to be live on all the metal raceways, enclosures on its way to the source? Even if the circuit breaker trips quickly, in that split second it takes to trip wouldn't it still zap you if you were leaning or touching any metal?
Thanks in advance
Thanks in advance
