cpblock
- Bloomington IL USA
I am working on adding VFD's to 2 20hp 480volt 3ph pumps. The original engineered design had both pumps on normal utility power with GFCI breakers.Before completion of construction one pump was moved to EM power panel without GFCI protection. I have been requested to change across the line starters to VFD's for reasons pertaining to flow and water hammer to plumbing on pump starts.Now the questions, 1. Is GFCI protection required on these pumps? 2.Will the VFD's work with GFCI breakers? Just for info breaker is Eaton/culter hammer HDFE 65k 80 amp frame. installation is all indoors , plumbing is plastic ,and pumps have seperate gnds back to building steel.
