Magic Gorge
- Lexington, KY
In regards to displaying time-current coordination curves, is there anything meaningful to learn from showing a main breaker ground fault against a downstream 3-phase breaker? How would the downstream breaker "see" the ground fault and operate? If the phase and ground overlap in this instance, should that be of concern? Also, would the same logic apply to medium voltage relays?
