poweringtech
Why is it that ground fault is only required for voltage greater than 150 volts to ground?
Is it safe not to have ground fault protection if system voltage is 240Y/139 volts for main disconnect having 1000Amps and above?
Has there been a study on the effect of ground fault for this system voltage?
Do you have refeence material on the explanation of this provision?
Have a great day to everybody
