myoung2165
- PORT ORANGE FLORIDA
hey everyone. i'm working at Holman prison in Alabama and have come across a problem i just cant find the answer to (i dont have my code book with me, im 500 miles from the shop). im installing some low volt controllers for water conservation. we have been supplied with plug-in type transformers to power the 24 volt controllers. these controllers are to be located in small pipe chases that are about 2 feet by 2 feet (the pipe chases are located in between two prison cells and accessed from the hallway outside of the prison cells). do the outlets i install inside the pipe chase have to be ground fault outlets or can i use a standard outlet. my heart says yes but the reason im asking is that we cant have these gfi's tripping because the toilets will not operate if the controller loses power. just to help you more, all the plumbing for the toilets and sinks for the two prison cells on either side of the pipe chase, is in the pipe chase.
