live2learn
I have a substation that is fed from the utility at 12kV. On the 12kV main it has a ground fault relay 51G. The circuit then splits to (3) different substations with 1500kVA transformers. All transformers have primary load interupter switches with fuses. The secondary of the transformers do not have a disconnect switch and has as many as (8) taps.
Q1) If my 12kV system has ground fault protection does my low voltage need it in addition?
Q2) If I was to remove (2) taps to change from (8) to (6) then it would be code compliant?
