R Ralphie Member Location Hart mi Feb 11, 2011 #1 Does the NEC require ground fault detector on a 480 volt system.
cadpoint Senior Member Location Durham, NC Feb 11, 2011 #3 I'm with shepelec... Ground Fault Protection has a complete listing in the Index of the Code Book. I guess it depends on what the service is and and what the service will used for... MOS
W wirenut601 Member Location champaign, illinois Feb 11, 2011 #4 ground fault ground fault not sure what you are asking but here are two comments ungrounded 480 volt service needs ground fault detection 480 volt main breakers 1000 amp and over need GFCI protection
