Hey, I'm new here.......got a question on ground fault outlets. If you plug in a piece of equipment to a ground fault outlet and it keeps popping the outlet, but if you plug the equipment into a standard outlet it will work. Why is that. I was told at first it had to do with the neutral and ground on the piece of equipment being tied together somehow. Is that true?
