WBgreen said:On a 240 volt circuit two wire plus ground,ex.(electric baseboard heating)will the circuit still work if the ground is disconnected. My understanding is that the ground wire is used only for a failure condition such as a short circuit. Thanks for your help,
Is running with a short to frame but not tripping WORKING ?480sparky said:Will it work? Yes.
Is it safe? Absolutely not.
Jim W in Tampa said:Is running with a short to frame but not tripping WORKING ?
480sparky said:Yes. 'Working' and 'being a hazard' are two different animals.
Jim W in Tampa said:I say no its not working,producing heat alone is not working.If that frame is live it is not working its just running.This could easily lead to a fire.
480sparky said:OK, 'Operating' and 'operating safely' are two different animals.
If your truck has no turn signals, brake lights, horn and a missing rear-view mirror, will it still not get you to the job site?
Might go down if the AC kicks onhillbilly1 said:Wouldn't the efficiency per KWH go up if it caught fire?![]()
