Electriman
- TX
Greetings,
I have an electrical room that the owner wants to have a ground loop around that electrical room. The service size 3000 A. I was wondering if there is a requirement in NEC or other applicable codes that determine the size of the conductor. Per NEC 250.66 the grounding electrode conductor size is 3/0 but does not talk about a ground loop conductor size. Please advise.
My second question is the tap conductor size to bond building, switchboard and other gear inside the room, I can still use 250.66 and select 3/0.
Thanks
Thanks
