My colleague suggested that I need a ground loop or counterpoise installed for my pad mounted 3phase, 300KVA, Delta-Wye connected, 208/120 volts, 12,460 volts primary transformer. I have a ground rod installed now which obviously goes in to the ground (I believe it is 10feet)and this is what I have seen done by a previous contractor's design.
I assume I must tie it in with the facility ground for the building located nearby if I use a ground loop or counterpoise?
Can I go without the ground loopo or counterpoise is question 1?
Do I have to tie it in with the facility ground for the building if I must use a ground loop or counterpoise is question 2?
