I Was hooking up florecent lighting to a temp panel and the temp panel is fed from another finished building . I hope you can view the videos on my Google drive below and you can see what is happening. Is this what they call a ground loop?Didn't use a volt meter but both was safe to touch.why does this happen?
Also everything is hooked up fine and works fine.
https://drive.google.com/file/d/0BwsR7koMMMk2bkdtMG0xUERHOFE/view?usp=drivesdk
https://drive.google.com/file/d/0BwsR7koMMMk2VWRpS0RmZ2YzZkU/view?usp=drivesdk
