allenc4
- Michigan, US
- Programmer
I want to operate some radio frequency equipment at my residence. The manufacturer and good practice specify that the RF equipment be provided a short, low impedance ground connection using a ground lug on the chassis of the equipment. My plan is to add bonded ground rods on the exterior of the structure and expose a grounded bus bar on immediate interior, keeping that connection short. I know it is required that the new ground be bonded with the existing ground system. I'm also aware that this ground extension bonding must be completed using irreversible splice connectors (Cadweld, compression type, etc.) I intend to have this electrical work done through a licensed contractor.
My question: if I take power for the RF equipment from an existing outlet and its existing ground wire located near the new ground do I need to worry about any sort of "ground loop" problem? The equipment will be connected to both the new ground (via the chassis ground lug) and the ground provided by the power outlet, and these two ground conductors would form a loop about roughly 25' in length to the point where the splice will likely exist.
I've done a lot of searching looking for insight on my worry, but haven't found any clear answers. I suspect the answer is no, I don't have to worry, but I'm not 100% sure about that, and I'd like to be.
