We are installing a small ground mount array about 15 feet from a costumer's outbuilding. The outbuilding has an outdoor panel where we will connect the feed from the inverter. Originally I was going to locate the inverter and disco on the structure of the ground-mount but now I would like to run the DC conductors in a trench to the building and mount all the gear there. See any issues with that? Next question is about the GEC, should I connect it to the ground mount frame and run it to the inverter in the trench? I was planning to pound 2 ground rods at the array. Thanks
