Mythumbs
- Washington
- Electrician
Friends are cleaning up family homes fed by a non-grounded 220v city wide system. They are asking me should they ground their service panels?
Where is this system located in what foreign country?ed by a non-grounded 220v city wide system.
Norway tried to go with a countrywide ungrounded system and they had a lot of those kinds of problems. Nobody knew where the first "fault" was.If the source isn't grounded or bonded, what would a ground rod be a path to? But then again, how do you know what another customer on the same transformer might have done? If customer A, grounds phase A, and customer B Grounds phase B, and customer C grounds phase C, you are going to have lots of unhappy worms
If the question is whether they should ground the metal parts of service panels and other non current carrying parts, etc, the answer is probably yes. This will possibly allow residual current devices to sense unintentionally grounded (ground faulted) conductors and open.
For such a DIY question to persist without getting closed is unusual, but equally informative with how well the members addressed the topic.This is the ultimate in bad DIY questions. OP may or may not be an electrician, but is forwarding a question from a non-electrician in a foreign country with different system designs and different rules.
Not necessarily. It may allow detectors to indicate the first fault.If no part of the system is grounded, grounding metallic non-current carrying parts is a useless endeavor.
-Hal
I really liked it better in the old days when all posts were in a common forum.This forum's owner should add additional categories. There is "Canadian Electrical Forum". So maybe "European Electrica Forum" then "California Electrical Forum".
In any case, we're also not assuming that no part of the system is grounded
Mythumbs: A grounding rod is to reduce the likelihood of damage due to lightning. ...
In my opinion. The only place that you need two ground rods is around Florida. I have never lived there, but people I have talked to from Florida say it's a real experience, including the alligators.
